Darn, darn darn and darn! well the t600's are now running ALIGN 600MX Brushless Motor(510KV) RCM-BL600MX. Do you think I could get it to fit? in my old frame?
Not easily, that's a motor designed for 12S batteries, RPM would be far too low on 6S so to use that motor you would have at the very least to convert to 12S, which would also need an new ESC. Even then you would still have to change the gearing.
You may get away with the 1220Kv version of the 600MX which is intended for 6S operation. You would probably also have to fit a larger pinion to get adequate headspeed, what size is the pinion that's fitted?
An outrunner will be larger in diameter too, do you have enough clearance between the motor and the frame to fit a wider motor in?
