I don't know how else to say it. I love the way this thing flies. I think I'm running my head-speed a little low (2900 rpm), so I'd like to know what everyone else runs theirs at. Also, I do like it a little on the low side since it tames things down. This is the biggest heli I've flown, so I can only compare it to my Align 450s. The Warp just seems really stable, and everything seems like it happens so slow. I think that is because it just seems so smooth.
I was doing some half flips and holding inverted. Then when I exited, i was flipping back out the way I came into it. I feel like I'm using an extreme amount of collective to get it to pitch back out from that inverted hover. Anyway, for the last time I tried it I decided that I would pitch out from inverted just a little bit and give a ton of negative collective. My thought was it might look like a big rainbow. Well about 50 yards across the sky (estimate) the tail blew out, but luckily it righted itself and regained the tail. Could the tail blowing out be due to the low headspeed? Could it be that I started to stall the heli? I'm running Ikon as my FBL, and maybe that could be a problem with the way I have it setup. That is the only time I have seen anything strange with the tail on this bird, but I only have about 5 or 6 flights on it.
