I ran a 3S 5000-30C battery and a 4S 5000-40C battery both batteries and the esc's are slightly warm but not hot. The hexa is right at 3.5 to 4 lbs so is this normal running temp for setup like this on a hexa? I also run 30Amp esc's and the hover time was at 5 minutes. So I'm just wondering if this would be a normal operation. This is the first time that they have felt warm and I always check then after each flight in case I need to let it cool off before anther flight.
