The purpose for this thread is to help me remember all the things I have done to get this radio the way I want it. will also be adding videos shortly. I have to solve yet another problem.
I went into castle link and decided to some fishing around. I turned off fixed end points, heli governor and updated the gear ratio information. I then set the target head speeds at the bottom. I used 2700 3000 3200. Now castle did its thing with my numbers and told me to use 30%, 70%, 100%. I then went back and set fixed end points, external governor with auto rotation bail out turned off. I also put auto cut off to custom and set the cut off voltage to 3.4.
I then went into the Vcontrol and rest my esc output numbers to 30 50 70 percent. SO I hope this will gives me better results and actually shows the head speed on the radio. It supposed to show the head speed through telemetry, which I have activated on the radio. This should help make sense of what I did and then revert back to. My head speed changes with the banks like it should but I am not seeing the head speed through telemetry.
According to Vstabi this is what your Castle ESC should look like for use with the NEO governor:
