Mda1701d
Hello all again, here's the latest problem!
After a tail servo bail out on the blade 400, I found the servo was getting red hot. Tried a new servo first, but it did the same thing. Align 750 gyro set to digital, so wasn't that. I had to put a new esc in the heli a while back, but all has been fine for a few weeks. Testing this on the bench, with t hold on, no inputs, the esc gets very hot within a minute or so. It's a cheap ish JPEG energ pro, didn't used to get hot after a fight, so I wonder if it's gone up the spout? Could it be over voltage on the servo causing the overheat? The servo is a hsg508 hitek.
Opinions would be great, thanks!
