I am extremely unhappy with the manner I ended up leaving my wires. I would like to redo the whole thing.......any suggestions of where I could look and find precise suggestions for the Align 450 Plus? Maybe a thread with pictures or a detailed video? Tks.
I did mine the same way, it left the build super clean with no wires at all on the outside of the frame.Hi Lambar, I did mine this way:
Align trex 450 pro complete build video (freddy can fly) - YouTube. The only problem I have found is that you need to make sure before you CA under the bearing frame is that you properly flatten the wires to allow enough so they are not tight going into the 3GX.Minimum amount of CA as well to enable you to remove
What does Freddie use to create the magnet look to secure the ESC wiring above the servo?I did mine the same way, it left the build super clean with no wires at all on the outside of the frame.
Great. Where will I put mine then? Underneath? Will it fit?he doesnot use a rx he uses sats instead.
he drills some holes in the battery plate to secure the esc then uses some cable ties (zip ties) to secure it.
i built mine the same was apart from running the tail servo a differnt way.
ive got to take mine to bits so i'll post some pictures as i rebuild on the crash thread (Another successful rotavator conversion).
