crashlflash
Hi There,
I recently completed the set-up on a Cypher 3D after watching an excellent C-Help.com YouTube clip.
All was good apart from the fact that I could not reach full suggested pitch of 7-8 degrees in neither positive or negative throws. The servo links are at the suggested spacing of 10mm from center to ball joint , only -6 to + 7 degree pitch could be achieved as a max.
Question; do I extend the servo travel limit via the Tx (a Dx6i) or have I possibly missed something mechanical?
If its the Tx, on the Dx6i, do I go and in to adjust the "travel adjustment" for each cyclic servo or is there something that I can do via the "swash mix"? Apologies if this may seem basic but I am on a steep learning curve...
As for the heli, it would not take off properly with a weak hover around 2ft. This unfortunately ended up with me picking up bits of blade and a bent shaft....now to find a shaft...the Rip..x distributors don't have stock. I have a spare Cypher but am now also wondering if my energies are best concentrated on having something else up and running.
Advice re. the pitch issue and a possible docile learner 450 would be welcome.
