coolgabsi
Super Mod & DEAL KING!
Trex 450 pro DFC
OK So Battery 1 Monday
Flying around.. Quite windy day.. VERY windy.. but that makes it fun ! heli goes FAST! and i am just doing circles.. Last circle, the heli blades are CRACKLING its going so fast with the wind, I pull a hard left as its coming nose in towards me heading with the wind prety fast, and I cant pull anymore.. it makes half the turn but elevator seems stuck and its drifiting and going FAST! Well guess what, the force / speed of the heli was enough to lock up my elevator servo and I went straight into a stupid tree.. I had hit TH before getting in, so I damage the blades and loose the boom supports, main gear, main shaft, featehring shaft and ofcourse a servo and a servo ball pops out.. so .. Damage was real but .. I have had worse..
Bring it home, fix it up .. New align blades.. and take it out today ..
Battery 2:
Flying around.. Bird is Beautifully smooth and MAN Rock steady... again VERY windy and ghusty but the tail wouldnt Budge.. I did tic tocs, and what not. .and the thing just took it like a beast..
Coming Nose in inverted towards me , going in for a hurricane so banked pretty sharp.. blades shining bright in the sun and all of a sudden, it goes to nose up, tail lost 90 degrees, and then within a flash of a second, the tail makes a full 360 turn and the heli is still heading towards me just racing at Idle up 2 with the wind!! and then with all its being the tail pyros out, and OUT of CONTROl! I am like MAN .. I try do do differnt things to bring it in control somehow, but nope, Hit throttle hold and it hits the ground tail in .. Tail bent 90 degrees , main gear, main shaft, feathering shaft.. baldes.. tail blades, tail blade hub, tail gears.. the usual.. BUT WHY DID IT HAPPEN. When I recover it from the crash site, the tail servo wasnt stripped, and was trying to puch hard on the bent tail push rod.. so the electronics didnt quit.. Something else had to be wrong.. .. .. . ..
WELL .. two things happened... one of the two mechanical faliures caused this .. : one: the tail slipped out of the boom mount a bit and lost throw and lost control.. But still wouldnt piro out.. I am thinking, my last crash , and the whack flying I try to do.. caused the silver part on the TT that goes into the TT gears, just stripped loose from the torque tube black part and I lost power to the tail... That would cause a ful loss of control. .. Why I say this.. when I pulled the tail out, that metal part did come loose pretty easy..
So .. its grounded again. Luckily. I have everything to fix it. so it will be up in no time. .. but it hurts nonetheless. lol
makes you loose confidence in your flying. But accident happen.. Just hate it when they are mechanical faliures.
Battery 2:
