Turnigy radio glove - with heater
stokke
As you may know; Norway is not known for long stretched beaches, clear warm water or big palm trees - but cold, COLD, climate. And now that fall has "fallen upon us" as it were, I'm not laying down the radio just yet!
So I went ahead and ordered a radio glove (or radio mitt). I also got some heater elements which can be powered with 7~12 V batteries.
Heating elements, control box, wires and temperature sensor.
Trying out for how the wires should be placed around in the mitt.
Velcro tape for mounting.
Velcro taped to the bottom of the mitt.
Applying my master sewing skills ;)
Heater elements in place.
Stuffing temp sensor inside one of the holes were a element wire comes out.
Zip ties.
Securing the control box.
Performing initial test with a 2S lipo, using alligator clamps. (Indoors).
This is before connecting battery. That's 75.2 degrees Fahrenheit, for you Americans ;)
About 5 minutes after, at 70% power.
(80.6 degrees Fahrenheit).
Initial test success!
Went to my LHS and got some JST connectors.
Soldered.
Shrink wrapped.
All wires in place, devices secured.
The 2S lipo is to just lay beside the control box.
Outside tests, with actual flying.
Outside tempereature.
(59 degrees Fahrenheit).
After the first flight I raised the power to 50%.
After my second flight was finished, the device was off - and the 2S 1000mah was completely drained! :(
And no change in temp either :(
Can't say the outside test was a success. I did feel some heat radiate from the elements, but the glove was not "filled" with warmth as was my hope. The mitt did it's job though, I didn't get as cold on my thumbs and fingers as I would with no mitt.
In the initial tests I did try a 3S lipo, and that really put some juice through the heaters! Actually I was afraid the thing would catch fire :D BUT, as I see now, the 2S may not be the pack for the job - so I might do a 3S set-up none the less. We'll see.
All I can say is I would be very leery of the heaters being under the Tx like that. I think I would have put them on the sides closest to your hands. But, I know you love your DX7s so I know you won't let it melt it lol. Hope your next test goes better. You may want to think about a 3k 2s if the 3s gets too hot. Remember, a 3s is 12.6vDC at full capacity, just over what they suggest. I would even bet you can get a 4k 2s pack in there with room to spare.
stokke
Yes, Tony. I have been pondering the same thought. As mentioned earlier, the 3S is a bit too crazy. I'll check into the larger 2S packs.
Also ordered a lipo monitor, which will sound an alarm when the pack is getting low. Don't want my packs to be destroyed due to draining them empty :)
stokke
After initial testing of my radio-glove with heating, I concluded;
The wire gauge on the 1000mah 2S were too small, as the leads got hot during use.
The 1000mah was drained after only about 10 minutes use (not even full power).
So now I got some upgrades :)
Got a 40C 3000mah 2S lipo.
Changed the connectors to 3mm jacks.
Got a lipo alarm, which will sound a loud audible alert when lipo is getting low.
Testing endurance, heat build up and quality of set-up (indoors).
Thermostat tuned in at 70 deg (F) the entire test.
Room temperature before test. 73,4 deg (F)
The 3000mah lipo gave out after almost 46 minutes :D
Temp inside glove had risen to 30 deg C. (86 F).
Very satisfied with results :D
Next - outdoor testing.
breeze400
Spagetti Pilot
Sounds like you may have it now! Let us know! It soon will be cold out hear in th northeastern part of the US. The weather is degrading rapidly! Lol. We all may need to make cold weather gloves too!
