Turnigy 9x led lights channel 8.? Help
Jay
I received my LEDs in mail. But am having hard time locating the a switch to put them on. I have a turnigy 9x and 8x rx. Right now I have my led plugged into ch 8, though I have others open of course it a hk450. Again having problems with gettings settings in order for proper switch.
From what I understand about the LED's, which isn't a lot, you plug the LED's into a power source matching their rated voltage requirements and not a channel on your reciever. Now having said that, I've seen certain LED kits that also come with a component that allows them to be switched through a channel... So what you are asking about doing will depend a lot on which LED setup you purchased and there are a lot of different ones available out there.
Randy
Jay
Yes mine is kit can hook up through channel. Just need to configure TX. For on and of also have a camander that I will also want to set up this weekend also. Should be same scenario with configuration of TX I think.
