Most likely the problem is that I am just missing something.
I have my two MG servo's hooked up to my ESC on my 49" wing. I turn on the Tx then plug in the lipo...move the right stick and the servo arm moves very very little. The servo travel isn't any where near what it should be. I've rechecked the Travel Adjust..all channels are set to 100%. I've rechecked the Dual Rates...all are 100%. I do have "Elevons" selected in the Wing Tail Mix. I do have the Elevator mixed with the Aileron in the Mix 1 setting....both channels are set for +100%. I even went so far as to swap out the servos and still get the same result.
Does anyone have any suggestions?
If you need me to post a video showing the limited servo arm travel, I will do that.
