Double check that your motor is turning the right way. If the motor is running backwards, the main gear will spin (because the pinion on the motor is engaging the main gear) but the one way bearing isn't being engaged. The motor should spin counter-clockwise so that the main gear will turn clockwise, therefore turning the head clockwise.
