It connects directly but check the pin out. It's not a conventional spektrum or servo type pin out.. Check the three wires, abd make sure signal ground and power are where they are supposed to be
After flight, did you check if magnets were still there .. ? Sometimes those suckers fly away cause they were not installed with a good glue or epoxy.
And as far as that "V" curve is concerned, 100-95 isn't gonna make any difference at all
nitro V curves look like 100-80-60-80-100 . The mid point is quite a bit lower, and that's to prevent overspending.. Which your friend intends for it to prevent if gov doesn't work.. But with ikon it's not possible to run that low if a mid point as that basically means governor has three head speeds
But it's not hurting you running 100-95-.. It's just not gonna help at all at a gov failure
