You are about to get many different responses to the question. I would recommend using align since its a t-rex. Do you have to, no. Align blades will handle most flying styles.
I use revolution blades which cost more and are a great all around blade.
Since your looking for sport flying there is no real need for the most costly blades. Bottom line is if you stick with carbon fiber blades you won't have to worry to much. Just make sure you do you weight and cog checks.
