Erfan
Hi guys!
I got a wobble issue on my trex 450L, it wobbles sideways (aileron) but this only happens on higher head speeds.
All my idle up settings are minor v shaped (no governor), the first one is between 70-75%, second one is around 80-85% and the third one is around 90-95%.
The wobble only happens on the second and third and it wobbles hard.
On the first idle up there is no issues, same goes for ordinary throttle setup (0-50-100).
The pitch is same on all idle up settings.
I'm not sure were to look anymore, I have looked at all the parts and nothing seems to be broken or bent. The blades have a small dent but I have balanced them.
I have played with both gains but it does not do anything for the wobble.
The tail holds and it does not drift but as soon as I move around it starts to wobble hard. It wobbles is even more noticeable if you fly straight and then rotate the heli 180* while still flying in the same direction (basically flying sideways).
Some info about the heli:
Trex 450L
Stock parts
3gx, latest version
Any suggestions?
Trex 450L
Stock parts
3gx, latest version
Any suggestions?
