Erfan
Hi
I just build a new trex 450L with gPro. No vibrations, no oscillation but it has a "dolphin effect" on FFF. I tried to lower the swash gain 5 clicks at the time all the way to the lowest setting, did not do much.
I tried going the either way, did not help either, strangely I could have max gain on swash and no oscillation which is strange, but nothing changed when it comes to the dolphin dancing on FFF.
And the head-speed does not seem to help either, tried different settings there as well. Small v-curve around 70% and then on 85% and last at 95%.
Everything is brand new, never crashed. Nothing is bent, no vibrations what I can see, it does not wobble or oscillation issues on swash or tail.
The servos are Align DS430M. Two of them are brand new, the third one is a used since before and its sitting on elevator. But behaves as it should from what I can see, no stripped gear.
Before I change the servos (I got 3 Align DS416m in the package) I thought checking with you guys, any suggestions on what it could be?
And how come there is no oscillation even with the highest swash gain, isn't that strange? I have only changed settings through the bluetooth (on iPhone and Andriod), it seems to update everything when I change but perhaps there is a bug?
I have build one exactly the same before using another gPro gyro with stock settings, it flies perfectly... But this one just does not want to behave
