Hello All. Doing my first build of a TREX 450 v2 3GX. Having trouble fitting the motor wires (between the main motor and the ESC) under the plastic front plate on the frame (where the battery mounts). The mid-wire connectors are very stiff and do not allow me to position the wires so that they will not contact the main gear or motor gear. Any suggestions? I've looked at the forum with wiring pictures which is helpful, but does not help for the exact problem because of the Align design change with the v2 3GX which has a larger battery mount/front cover.
Thanks for the great forums and video, very helpful.
