500 Trex 450 Pro Tail Twitch
Harford
I have a Trex 450 Prox Fly-dared with GP780. It is a stock standard Align machine. Flies really well but there is a small twitch in the tail, every few seconds - not dramatic, probably moves around 10-15mm. Is this a gyro setting issue which can be eliminated ?
Many thanks
Michael
Many thanks
Michael
It could be a gyro issue. Might be a tail servo issue too. Try turning the gyro down a tweak or two. Make sure your tail slider is centered. Shoot, it could also be a tail servo going bad. Process of elimination is going to determine your problem. Hopefully, others will have a better suggestions then mine. Good luck!
