Hi all,
I've got myself a Trex 450 PRO with a Spektrum DX8 TX. It's been a pretty good build - my newbie-ness showing when putting things on then needing to take them off again to align/calibrate/wire up.
I'm now trying to setup the gyro. I do the E LIM which is fine so no need to reverse it in E REV. I do the A LIM but in A REV it's reversed. I move the aileron stick but the Status LED doesn't change.
I continue on into the Rudder. Turn everything on, hold the 3GX SET button for a sec or two and I'm into Rudder settings. I move the rudder but nothing. No movement by the rudder servo.
After all of this when I simply turn on the heli the gyro looks like this, which I don't think is right.
My AR8000 is wired like this.
I'm note sure if blue should be in GEAR or AUX2. In stokke's post he originally had it in GEAR, but in a later pic had moved it to AUX 2.
Any help is greatly appreciated.
Dave
Dave
