transpro61181
Attempted a maiden hover today but it has an issue where the swash wants to start tilting to the left pretty hard (viewed from the rear... tail facing me) before i even attempt to make it light on the skids causing the heli to want to pitch left drastically almost causing a blade strike. (with training gear on!!) both the pots on the 3gx are set at the 12:00, i also tried 2:00 position with the same issue. Everything has been set on this heli VERBATIM to Tony's 3gx setup guide. The swash has been leveled perfect with a swash tool. The swash correction directions are all correct according to Tony's videos. Any recommendations?
