I just finished getting up and organizing the pics from Day 1 of the build. I was afraid to start yesterday, as its one thing to say you're going to build one, quite another to do it.
If it wasn't for build help videos, no amount of exploded view diagrams means Jack. Not to me anyway. I assumed the manual actually explains how to build it. It shows you where the parts go, gives link length and specs, but not what order to do them in.
If you follow just the book, and have never done anything like this before (ME!), You will have problems. Example. The prints for the heli, and the sequence of assembly doesn't make sense. Their way you install the servo's in the frame, and then install and 90 the servo horns and put on the ball links. That would have made me mental to do it that way. The video's showed a much easier way, where you setup the servo's out of the frame, get the horns on, subtrim, and then install in the frame.
I know you guys have maybe a lot of experience working on all kinds of equipment in your life, especially in farming country, so the sequence of the build is more based on real life plain common sense. Not so much with my life, just consumer electronics, and operating mining equipment.
Its been stressful, but enjoyable when I complete a build portion, and its been tripled checked before threadlocking it down.
Now I'm a good bit done, I'm not worried as much about finishing the mechanical building part, thanks to the videos and exacting parts and measurements in the literature. Is now a question of setting up my first ESC and Gyro, since I've never that either, the its more complicated.
I'll say one thing about Align. The quality of this heli kit is superb. It may cost a lot more than HK type clones, but everything is very solid and assembles exactly as they say it will.
The head has to be taken apart on these heli. They come pre-assembled, but only as an example. There was no grease on the thrust bearings in the blade grips. You need to grease those and the spindle. They aren't threadlocked either, since you ARE supposed to take them apart.
So, day 1 was I think productive. Never done it before. I worked on it from 11:00am yesterday to 02:30am today. Pretty tired today, and need a break from it, but will post the progress.
Almost forgot something very important. Pay attention to the last picture of the Finless Bob 450Pro mod. You will have one small silver screw left over from the from the DS4 servo horn install. They give you 4 horn, ball links and screws for the center of the servo horns. Take a 1/16" bit and drill a hole from the rotor tube housing and into the rotor tube. Not far!!!!! Just through the tube. The screw will self tap, and with thread lock will secure the boom. The tail boom clamp will not hold it good enough. After installing the tube and TT, you can pull the tube out easier than you think. Bob said he's lost the tail on 500's and 600's, before he started doing this safety mod.
