General Trex 450 mix up
Badbowtie007
So I crashed my trex 450 and after I put it back together and hooked my spectrum AR6115 receiver and then turned on my DX6i. When I throttle up the elevators moves and when I move the elevators it throttle up. How can I switch the two. The crazy part is I never mess with the radio
stokke
You probably switched the connectors around on the Rx.
THR/ESC wire in ELE port, and ELE wire in THR port.
Rear servo is your Elevator, right servo is your aileron and left servo is your pitch or Aux1. Make sure they are hooked up like that in the Rx and it should work fine. You may need to reverse the ail and pitch servos if it's still not right.
