General Trex 250 spools up while using rudder trim lever. Please help newbie
dcmjtrex250
While attempting to correct the rudder trim on my futaba t6 to make the tail neutral the heli spools up! Is this crazy or normal? Yes I'm a newbie and willing to learn so I'm all ears!
1. Main blades are not connected to heli
2. Throttle stick on transmitter is at zero
Can you get us a video of what it's doing? More on the Tx than the helicopter? It will help explain this a LOT more.
dcmjtrex250
My mistake I meant to say I was adjusting the channel 3 throttle trim lever. See video below
callsign4223
You are changing the wrong channel on your transmitter. On Futaba transmitters channel 3 is designated for throttle. If you are trying to correct a tail issue you need to be changing the trim on channel 4.
