Motors Traxxass tmaxx motor
Adam
So even after the rebuild i cant keep this engine running. The engine sounds great so instead of new engine i think it is a fuel problem as in like the carb. Is my thinking correct or should i start with new engine. Now this is the one tony rebuilt so Tony the engine looks great So your opionion on this would be awesome. That last video what was happening has alway happened so i think the carb is at fault. I have no problem with the heli nitro so this is what i am basing my theory on.
I would take the engine out, pull the carb off and rebuild it. Blow everything out with carb cleaner or brake cleaner and make sure all passages are clear. Then, replace all of the fuel line, you might have a hole in it. And you may need a new tank, there could be a crack at the output, or you could not be holding pressure from the muffler. Hope this helps.
