I have the Tx that came with the Blade CP. According to the Phoenix sim website, it is compatible but will require a mini din adapter. I have a cable that has a mini din plug on each end. I want to cut one end off and connect a 1/8 mono plug (like what headphones have but two conductors). The mini din has 4 conductors and the outer shield. I don't know what wires to connect to what. If someone has this adapter, a quick continuity check would be helpful. There are two conductors on the phono end and 5 on the other...how can this be without it being digital, assuming that is already is.
