A few weeks ago, I replaced the stock white gears on the front drive assembly, on my Trex 600 Pro DFC, and the torque tube because I had stripped out a few teeth on the front drive assembly. I installed new black gears where I could. The manual says that the tail drive gear is 34 tooth, so I bought a 34 tooth replacement.
The weather was spectacular today so I went out to fly a few packs. After a few minutes, I noticed an odd sound. Set the helicopter down and unplug everything and I find that the torque tube umbrella gear is missing 3 teeth and the front drive gear is missing 3 teeth. This has to be a "gear mesh" issue. Perhaps I have the mesh too tight and its stripping teeth or perhaps I don't have the gear mesh tight enough and it's stripping teeth. How do I know if I have the gear mesh set properly? I really don't want to have to replace these gears every 3-4 flights because I'm constantly stripping gears, lol.
