I'm sure that most everyone on here knows I own the mCP-X. You may also know that I have upgraded it with a carbon fiber frame, brushless motor, and thanks to the member "Adam", I have a set of KBDD main blades on it.
The issue I have been having is with the tail. When I did the brushless conversion on the main motor, I put the 120sr tail on it. Let me tell you, when it worked, it was the most solid tail that I have ever seen. Then it died, after only 10 flights. So I put the dual tail mod on it. This worked well for a while.
If you check out the "Official Grass Cutting Video Thread", in that video I posted, I did some inverted grass cutting and the tail was holding fine. Well I wanted to get something better on video so I went back out with fresh batteries. The top tail motor broke off, the blades cut the wires to the only other tail motor that was still securely attached and it went down in a blaze of glory so to speak lol.
This ended up taking out the two tail motors, and the landing skids. I'm still having an issue with the swash, but it's just old and worn out and I need to replace it. Just have not gotten around to it.
This thread is just to chat about the mCP-X and what I'm doing with it now.
At this time, I have the neon green / yellow main blades on it as well as the skids that were donated by Adam. I'm charging the batteries right now and we are going to go out on this cold morning and see what it will do. I also have the DX8 charging as well.
So the next post in this thread by me should be an update on how the flight(s) went. I'm hoping I get more than one anyway lmao.
