Hi chaps
I know ive posted about my Honeybee CP3 before about putting a dx6i into it, well this doesnt work no way no how so i gave up (just not worth it)
The problem i have and have had for a while is.... that the swashplate goes down when it should go up.
a while ago i did all the setup properly (because i know what im doing since i bought it last year) i set the blades to 0 at mid stick etc... but when i tried flying it , the dahm thing wouldnt lift off the ground, i noticed the swashplate was going down, and despite my efforts then i still couldnt reverse the throttle/swash movment.
this wasnt a problem to get round at the time because i just added a few degrees pitch to each blade, meaning it lifts fine at around half stick and does fly very well considering, and has been a great practice heli abit like a real sim, my flyings improved because of it
i have tried everything i can think of in the way of reversing things even plugging the wires in the other way round (incase its wired arse about face) didnt work, ive turned the servos up the other way still no luck, the only luck i had so far was to turn the throttle wire round the wrong way, reverse the throttle on the std TX and with it strapped to my carry box plugged it in , this worked as far as getting the swash to move upwards but i had no power to the motor, and ofcourse the throttle stick at the top of the tx
i thought about turning the throttle stick around in the TX itself or at least the internal wires themselves, does anyone think this might work or even have a proper solution to this problem
its an esky honeybee cp3 with 3-1 mix controller and std ET6 TX (so only manual reverse etc)
as usual im at the mercy of those greater than me with the techy bits
with thanks
paul
with thanks
paul
