Wayne A H Degagne
hi im wayne im new to this site and new to rc trucks im starting a rebuild on a traxxas tmaxx 3.3 rearend completly stripped out lots of work to just wondering if there were any complet rebuild vidoes on this truck
try to put a tiny bit of axle grease and just a bit to have the gears stick to the grease and i did the same thing to my traxxas s-maxx trx 2.5 rear diff and it work well and so far no problems yet and besides the transmission will have enough torque stir up the grease inside the rear diff and in order to put grease in the rear diff and all you have to do is take a small dab onto your flat head screwdriver and then apply it on the gears and if it needs a tiny bit more and just add a tiny bit and till the grease sticks to the gears and if it does not work and you can clean it with WD-40 and then apply with diff oil, or you can ask the hobby technicians about what kind of diff oil should you use and i hope it works for you and good luckhi im wayne im new to this site and new to rc trucks im starting a rebuild on a traxxas tmaxx 3.3 rearend completly stripped out lots of work to just wondering if there were any complet rebuild vidoes on this truck
