I am building a tiger moth 35" wing span. I am planning on using MPI EPU-6, a 9-7 prop, MX-9208 Micro ESC all from MPI and a 13C 2S 1320mAh 7.4 LiPO Battery, as suggested in the plans. I am kinda lost about receivers and radios, I would like to have a radio with 4 channels (I know I only need 3 with the tiger moth) that I could use it with other planes, bind and fly type stuff if possible. I have been thinking about getting a super cub offered by hobbyzone, with spectrum components. If I want to use the TX that comes with the cub and the tiger I am building I would need a spectrum receiver installed in the tiger, correct? But, the way I understand it the ESC is incorporated into the spectrum receiver. How do I tell which one I need if ESC, motor and battery are supposed to all match up?
Basically I want one TX to use with other planes just not sure how to go about it with out spending alot of money. Although I have learned that you can spend it now or spend it later.
