falcan
Hi from Australia may we have the thrust angles of the electric trainer epo foam plane please
derrick007@dodo.com.au
We have control (plastic) inners and outers for control for tail section , there lighter don;t need no more weight back there on the tail area
its all coming back,mounting servos under the wing on the CG mark three quarters back from the leading edge (about ), or placing them (servo's)for balancing is better put a piece of tap 4mmx6mm for balancing the model under the wing on the CG mark, so the mark can be seen when the wing is on for balancing for flying straight and level
the leading edge bulk head has one 5mm hole each side for push rods inners and outers I make both ends adjustable for setting up or one end
When the balance is finish I put the servo's blocks in using spruce hardwood
and threaded rods with horns both ends for adjustments
I USE INNERS AND OUTERS
SHOWS HORNS FOR ADJUSTMENTS
THIS ONE SERVO MOUNT PUT ONE MORE ON OTHER SIDE OF FUSE RUD/ AND ELEVATOR
FORWARD OF c.g if more Balancing is nedded or behind
one third back from leading edge good start
