im going to elaborate this. i have a dx6i tx, a exi 450 heli, i set my pitch to 0 at mid stick, high i got +11 low i got -5. i set the pitch with linear pitch and throttle curves. i then adjusted the throttle curve to 45, 47.5, 50,75,100. the pitch curve is linear. these curves are on normal, when i mid stick i get 0, high is at +5 low is +1. when i put the throttle curve back to linear its back to -5, 0, +11. what did i do wrong in my setup? i thought i followed tony's advice but i must of messed up somewhere. i dont have the adjustable links at the clear top of my head that you would use to adjust the pitch with.
