nitro208ca
this is going to be a hard question to ask, for the reason that my brain is asking the question faster then i can type it
I know that there is a formula to figure out thottle curve on the DX6I.
I know that everyone uses differenent settings from someone else, which is what makes this hobby fun. There is not one person that uses the EXACT setting or flies EXACLY like someoneelse...but...ALL base line/ starting points are the same (I.E -10 pitch at low stick, 0 pitch at mid stick +10 pitch at high stick.Once that is done tweek to your liking)
Now the settings that im going to use here are Just examples.
On the DX6I pitch the five points are (L) (2) (3) (4) (H). Lets say for example I wanted to set (2) at 26.5 for pitch, how would you figure out what the thottle curve for that point without taking out the aircraft and test fling. Lets say for example (3) is 58.5, how to figure out what the thottle curve should be for that point
I hope that you are understanding what im tring to say
If i havent said this before...I am a bit of a perfectionist when setting up my aircraft
(there has to be a base line or starting point to this)
