  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
General Throttle Curve (v) In Idle Up Mode And Governor (throttle Flat Curve)setup
Discussion in 'Helicopters' started by Benoy, May 15, 2019.
< Trex Battery Cell Count.. | Ikon Governor >
  1. Benoy
    Benoy Member
    Sep 21, 2013
    43
    0
    6
    Gender:
    Male
    Qatar
    Hi,
    like to know how the Throttle curve (V shape curve) in Idle up mode and Governor (Throttle Flat curve) setup will work together ?
    I know we need to have Throttle "V" curve for idleup mode. when Heli is inverted position if the THROTTLE is moved DOWNWARDS the heli will GO UP and when the THROTTLE is moved UP WARDS the heli is go DOWNWARDS. I Know Governor is flat curve to keep the RPM steady. My question is in idleup mode how the Governor will work or what type of THROTTLE curve to be used ?.
    Thanks.
  2. Tony
    Feb 21, 2011
    37,144
    1,458
    113
    They don't work together. Either you use a V curve and NO governor or you use a flat curve WITH a governor. You can't run a V curve with a governor.
  3. Geena
    Geena Moderator Staff Member
    Feb 3, 2017
    931
    70
    28
    Gender:
    Female
    Occupation:
    Certified Aircraft Welder
    Sebring, Florida
    Actually, yes you can. Governors like the Futaba GV-1 and the Aerospire MultiGove pro, actually want a v curve on the IU1 and IU2.
  4. Tony
    Feb 21, 2011
    37,144
    1,458
    113
    Okay, I have been corrected. Sorry.
Share This Page
