Yes and no. As with everything, there is a learning curve. Once you figure out what the needles do, and where the sweet spot is for your engine, it's pretty simple. As the humidity changes, you will just know "oh, I need to go 3 clicks lean" or "Oh, this only needs one click rich to run perfect". You can use a temp gun, but using telemetry is so much easier.
