450 Telemetry Module power up problem..
Rob Lancaster
Hi guy's, I've started to have a problem with my Spektrum TM-1000 powering up at startup. But only if the aircraft has been sitting for more than a few days or so. I have to power down every thing, even the TX and reinitiate the entire startup procedure and then it's fine. All other power ups are subsequently fine and no brown outs recorded in the LED. I've checked all plugs and connectors and their fine. I'm get'n ready to make my own power harness. I think there may be a fault in the original, I don't know at this point... Any ideas guys?
Really cables and connections are about the only thing to test and that you have any control over. The next suspects are the electronics themselves in the unit or the device ( receiver ? ) that you are plugging it into.
Rob Lancaster
Hey guys have you heard? Revolectrix has gone the way of the doe, doe bird. I almost bought a bump charger but at that time covid had the world closed up. Bummer to see them go...........
