Hello everyone.
I am starting to work on the assembly of my Tarot 450 Pro V2, which of course requires some disassembly. Funny how that works.
I am starting with the head, and taking it apart to clean, locktite, lube, etc.
I have it almost completely disassembled, but I have some questions.
The feathering shaft is pretty snug (not budging a bit) after the removal of the blade grips. I removed the collars, and the only thing left to get to is the rubber bushing on each side. The shaft does spin, shift, or anything.
1. My first question is, should I leave it alone, or should I continue taking it apart.
2. How do I get it apart from here? The rubber bushings are ready falling out (seem pressed in). I am not sure what is inside of that unit that it would be touching besides the rubber bushings. I just don't want to force anything without getting help first.
Next.
I have removed the screws and washers from the Upper Control Arms and the Radius Arms. The bearings are still in there.
3. Should I remove these bearings to clean/lube or leave them alone?
4. How would I remove them and separate the parts?
I can't seem to see how the radius arm separates from the control arm, even after the screws are removed.
One last question...
5. Should I grease all of these bearings I am finding?
Thanks for the help!
I will have a video to post for the build series as soon as I get it completely disassembled and then cleaned up and reassembled.
Next.
