FBL Gyro Tail wagging is too low of a gyro gain....right?
Mikker
Have a Mcpx bl that is wagging hard. Trying to figure out how to perform this gain setting on the RX. Am I correct in thinking the gain is too high?
IF the gain is too high, then the tail will oscillate very fast and violently. If it's too low, it will do what is called hunting, which is a very slow wag.
I"m not sure what Tx you are using, but make sure you have the gyro set to channel 5 and that you are in the positive numbers, or above 50 if you have a DX6i. I start out at 40 or 65 respectively.
