kywildcats
Found this site on youtube and it has helped me tremendously during my new 450L build. So far so good on the build and doing flight testing now. Just about have most of the flight settings complete until I get to the very end of my flight. Ok, let me back up a sec. During first spool up to bring up head-speed the nose with yaw left (if standing from rear, tail-in) for about a half a circle until my head-speed climbs then it lifts off with no issues. The heli hovers wonderful. It hovers like someone thumbtacked the thing in mid air. I'm very surprised after reading and hearing all the negative press about the 3gx. It flies good so far. Forward flight seems fine. Turning is the same. Then the second part I am not understanding. When I come down to land in IU1 then hit throttle hold when I'm very close to the ground it will land then start spinning rapidly, causing a slight blade strike. No big deal, but damaged my blades. Below are my settings.
Version: 3GX v5.0
Radio: DX8
Pitch curve: All linear
Throttle curves: Normal: 0-25-50-75-100 IU1: 85% Flat across IU2: 95% flat across
Heading Hold mode (green light on 3gx).
Transmitter gyro setting: normal: 32% IU1: 30% IU2: 27%
3GX PC software Rudder gain is 36. When I adjust my gain on my transmitter from 32% in normal mode the slider on the pc software increases. You think by increasing this value this could correct the tail swing right on lift off and after hitting throttle hold during landing? What rudder gain value should I be at? I know this is all relative, but does 36 sound low to you compared to what you have seen? If so, I'm going to try and update this value 36 to around 45-50 in the pc software and see if that makes a difference.
Any input or help would be so appreciated.
Version: 3GX v5.0
Radio: DX8
