Hey guys,
I have an Align 450 Plus which I replaced the FBL system with a 3gx, 2 satelite receivers with a DX8 transmitter. . It came with a 3GX MR. I'm running through the setup and everything is fine. As the heli is sitting there with no input from me, I notice the tail servo moving very slowly as if I was giving it right input on the stick. The only way it will center itself is if I move the rudder stick left or right but it will slowly start moving back to the right. It only does it in head lock mode not in rate mode. I don't know if it was doing this when I had the 3GX MR FBL unit on it. I don't know if this is normal or if there is something wrong with the 3GX or the tail servo. Thanks in advance.
Joe
Joe
