trainrider06
ok this is pissing me off! My tail when powering up is uncontrollable the more I power it up!
When correcting it it will flick from side to side correct right, it flicks hard to the left, correct left flicks hard to right. This is the DS760 gyro, that was holding like a rock with my DX6i, but now that I've switched it over to the DX8 is being a pain! It acts like as soon as i try to lift off that it's gonna spin on me either way...I hate to give up on it because I know this thing holds like a rock, but I am missing something for sure I think.
My radio is set up on the Gyro as follows:
Pos 0: 0%
Pos 1 61%
Pos 2 0%
i've tried setting 1 higher lower, still the same result, if I go above 0 on Pos 0 it comes off HH mode.
I've noticed my pitch slider seems a bit off center from what it was also, it sits just a bit closer to the boom, (have not adjusted control rod, from where it was, and it was maxed out and turned all the way in on both ends in order to get the servo, slider all centered on the last radio....and servo sits 90)
Pos 0: 0%
Pos 1 61%
Pos 2 0%
