Martinzx123
Good day to all the pilots,
i recently just upgrade to the longer tail shaft (48.5 mm) for my bird. Took it out for a test fly and seem like there is a bit of tail kick when i tried to do pitch pump both normal and stunt mode. The tail kick is not much anyway (just about 2-3 cm) but it drive me crazy as i am a neat person. I tried to adjust the torque precompensation on menu F of Beast Plus but does not make any difference. I even used different head speed and Gyro gain but no luck yet. Just wondering if any pilots out there have the same problem of better setup than i do that would like to share? My heli is original super combo 470Lp anyway.
And there one more thing i would like to know if some one have a fix to the vertical stabiliser bearing block (H47T004XXW). My one does not hold the tail case firmly on the tail boom. If i accidentally hit the tail on the ground the tail fin is not vertical any more.
I also attach some pics for both of my problems to help you guys understand better.
P/S: Sorry if my English is to bad and make you confuse when reading. Thanks
