I have come up against a problem I have not seen before in that the tail gear, the one that drives the belt has worn out. At least the frame at that point is plastered with white
dust, really plastered with it. The drive gear which is connected to the main shaft is black so it must be the small gear that drives the belt. I have never had one that is worn
quite so bad. Unfortunately the Align drive is different, the gear is in a different place so I will have to change the box has well. Is it worth going over to direct drive?
I'm not sure wether to stick with the belt drive or change to the direct one. Any thoughts would be appreciated. Thanks.
