General Tail Curve.
concodd
Hey Derek, if your still out there in cyber space,can you give me some novice tail curve settings. Cheers
I've never used tail curve.
It a mix from Throttle/Pitch to the tail
It was needed in the olden days before good gyros came along.
Now the gyros are better and you have something called Precomp in the FBL unit.
Its not always needed unless you are getting a twitch in high torque manoeuvres.
pvolcko
I'd start with 20-30% expo. 100% D/R. Will make it soft enough to take of and land and hover and get used to it. Then can adjsut as you like.
