Doum066
Greetings guys,
As i just finished building my new 550E DFC, i found out it was tail heavy, from the search i did on forums and stuff, it seems to be the problem of the last versions using the 600 boom and tail stuff... i guess if i would had installed the ESC under the battery pack or more on front on the frame that might helped a bit, but still... how did you guys manage to fix this? I'm using Gen Aces 5000 packs, some uses Gen Aces 5300 packs, and still have COG issue.
