450 T-Rex 450 plus..with DX8 tx?
Snowulf
Hello, I recently purchased a Spectrum DX8 DSMX radio and a Spectrum AR7610 rx, i was wondering if ther was a good video on switching the stock T-Rex 450 plus, with FB (rx Align R6GF)? I believe i will also have to reset servo arms and level swashplate? any advice would be very helpfull.
Thanks Sno
If that has a 3gx then all you should have to do is switch the rx out or use 2 satellite receivers.
Once that is done then you will need to run some setup stuff fir the new radio. End points in the esc will need set and any tx related programming.
Also the servos may need some adjustments. Not sure to what extent but it will need some.
You will need to transfer the servo leads over to the new receiver. Aile to Aile, Elev to Elev etc.....
Set up a new model Heli in your DX8.
Name it what you want.
Set swashplate setting to 120º
All other setting leave stock until after the next stage.
Bind the RX to the radio.
Your servos arms will be centred already within there mechanical range.
What you will have to do, is go into the servo sub trim menu and adjust the sub trim of your cyclic servos one at a time to get the arms back to 90º.
If your original link adjustment were correct, this should bring your swash back to level.
Now set your gyro gain
in the DX8 it goes from -100% to 0% (Rate) to 0% to 100% (Head hold)
start at about 35% for head hold.
Set up your pitch and throttle curves and you should be good to go.
