  3. Like Us On Facebook!
    Dismiss Notice
General Sub Micro Servo
Discussion in 'Airplanes' started by Capn Pete, Jan 10, 2019.
  1. Capn Pete
    Capn Pete Active Member
    Oct 17, 2017
    122
    1
    28
    Gender:
    Male
    N. Carollina
    Does anybody know of a substitute for the 5g sub micro servo used on the motor nacelle of a Mini- Convergence by Horizon Hobby? Their PN: SPMSA350. These servos suck and would like to find better ones. These are the ones used to rotate the motors from vertical flight mode to horizontal flight mode and back again.
    Thanks,
    Pete
  2. Tony
    Feb 21, 2011
    34,441
    1,336
    113
    I don't know of any that have metal gears if that is what you are breaking. There are some sub micro servos out there from places like HobbyKing from Turnigy, but they all look worse quality than what you have now.
  3. Capn Pete
    Oct 17, 2017
    122
    1
    28
    Gender:
    Male
    N. Carollina
    I know that metal geared servos/ digital are best, but as far as size, if I have a 5g, (don't know what that actually means), as long as I replace it with a 5g, I'm OK?
  4. D.O.G.
    D.O.G. Well-Known Member Goblin 380 Supporter
    Jul 9, 2013
    2,393
    75
    48
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
  5. Tony
    Feb 21, 2011
    34,441
    1,336
    113
    5g is roughly the weight of the servo, but they are always heavier than that. I just use it as a guideline. But most 5g submicro servos should work in place of the one you have. Just double check the case sizes on the spec sheet before you order. And also check the torque and speed ratings as well.
  6. rdsok
    rdsok Well-Known Member
    Sep 11, 2011
    1,374
    53
    48
    Norman, Ok USA
    Here is a servo database that you can use to look up servo's with All RC Servos - Servo Database
    Remember, as Tony said... the weight isn't the same as size except that bigger ones will typically weigh more but so will ones that use different components like metal gears. The class size ( sub micro, micro, standard etc ) is still a generic size and isn't specific enough, you need to actually go by the measurements themselves. The speed, torque and voltages will also play into this so you'll want to look up the specs for the ones you are replacing first before picking something else.
  7. Capn Pete
    Oct 17, 2017
    122
    1
    28
    Gender:
    Male
    N. Carollina
    Awesome! Thanks so much for the info! I had no idea who they were 'classified'.
    Capn Pete
Share This Page
