holtneil
Hi guys well I was out flying today and the goblin 630 started off as normal then as I did a hover the heli start a very slow spin anti clock wise I had No rudder control so I did a controlled landing all in a slow spin
Well the problem was the tail drive gear grub screw had come loose even with lock tight so was slipping also the tail shaft had slip out to the left side so I had no pitch movement to one side , took 2 seconds to fix with more lock tight and the grub screw up so tight its about to strip , first time for everything just glad I got it down with no damage
