Quad spec sheet / pinout for blade 350 qx2 flight control board?
Does anyone have the pinout for the blade 350 qx2 flight control board or any spec sheet? i texted horizonhobby and they don't have anything. I want to try binding a spektrum TM1000 to it but don't know what pins are what.
I had a look, but couldn't find anything either.
What are you wanting from the TM1000 for your 350?
wolfman76
here is the best i can come up with maybe you can zoom in and it will help give you an idea of what to do...maxresdefault.jpg try zooming in to see what is connected where
Thanks for the replies. I figured out that 1) I don't think a TM1000 can be bound to the 350 FCB and 2) I didn't need to anyway. I just installed the TM1000 as a stand alone unit. I was going to connect my TM1000 to a servo lead for power but that would normally be used by the gimbal and didn't know what pins where what. I've decided to just use the balance lead on my LiPo to free up the gimbal connectors for use with a gimbal later.
