It's not possible. The max power that can go to the motor is the max of the battery. This is voltage. The motor will only draw as many amps as it needs, the ESC does NOT push the amps. there is no way you can burn up a motor unless there is a bind or something and even then the heli would have went full throttle when it was given a fatal dose of power.
Just go out and get a new ESC. DON'T purchase a receiver pack, it's a waste of money unless you plan on flying nitro some day. Get an ESC, plug it into the Rx and hook up the battery. As I have stated in your other thread (not sure what one, you have had a LOT of threads on the same topic, please try to consolidate everything in one thread that has to do with the same aircraft) get an Align ESC for a 250 and use the Align 250 motor. Do this then report back on what the result was.
